Author Topic: 555 timer oscilloscope measurements  (Read 2408 times)
Offline GazmonTopic starter
« on: March 09, 2019, 09:02:11 pm »
Hi all,
I built a 555 timer flashing Led circuit in a breadboard , yes pretty basic but would really like to use my new oscilloscope to take some readings and get experience using it
It’s running at 5v , looking for tips on what and how I can use the oscilloscope to take measurements and waveforms etc
Running it from my power supply
Any help appreciated
Gazmon
« Last Edit: March 09, 2019, 09:15:06 pm by Gazmon »
Offline GeoffreyF
Re: 555 timer oscilloscope measurements
« Reply #1 on: March 09, 2019, 10:45:17 pm »
assuming everything is normal - just do it.   The best way to learn electronics is to try things and take chances.
The worst you can do is ruin an oscilloscope probe and therefore:
Oscilloscope set for 5v?
Probe 1:1
Assume the power supply ground and the oscilloscope ground are similar?   Check with a DVM to be really sure.
US Amateur Extra W1GCF.
The following users thanked this post: Gazmon
« Reply #2 on: March 09, 2019, 10:52:10 pm »
So I can connect my ground probe to the 0v
And my probe to 5v Vcc in etc
As long as my 0v is connected to my ground probe am I ok to hook on the pulse etc that flash’s etc
Offline IanMacdonald
    • IWR Consultancy
« Reply #3 on: March 09, 2019, 10:57:37 pm »
As a general principle I always use a x10 probe unless measuring millivolt levels. That way, if it accidentally gets put onto high voltage it's far less likely the scope will be damaged.  :wtf: :-+ :phew:
A habit from CRT TV maintenance days. It also means less circuit loading. When on x10 you need to compensate the probe for this particular scope otherwise your readings will be way out. The manual should tell you how.
To find the right vertical range just start at a low setting and increase until waveform is large enough to read comfortably. The scale is in volts/division so 1v/division would be suitable here. 5v/div will only give a one-division high trace.
As for grounding, depends if the PSU output is grounded or not. Generally it will not be. However, if the PSU negative is grounded then that is the only place you can attach the probe ground clip.
« Last Edit: March 09, 2019, 11:05:23 pm by IanMacdonald »
Offline TK
« Reply #4 on: March 09, 2019, 11:01:03 pm »
Yes, that is what oscilloscopes are used for.  Just keep out of mains, it is dangerous.  And connect the probe to something more interesting than 5V... like pin 3 on the 555 (output), etc. to see some moving trace
« Reply #5 on: March 09, 2019, 11:15:53 pm »
I’m using a Tenma 30v /3A bench power supply
Just connected to live and neutral outputs at 5v setting
Guessing that hooking onto 0v on my breadboard gives me my reference base
« Last Edit: March 09, 2019, 11:28:11 pm by Gazmon »
Offline Brumby
« Reply #6 on: March 10, 2019, 12:14:30 am »
A suggestion: Do not use "live" and "neutral" for the outputs of a power supply.  Those terms are pretty much exclusively used for mains power.
If you use them for power supply outputs, many people are going to think "mains" and go into "protect the newbie" mode, giving you all sorts of warnings that aren't going to make sense.
Offline Brumby
« Reply #7 on: March 10, 2019, 12:15:40 am »
If you are new to scopes, then this is worth watching (pretty much a standard recommendation, in fact)...
« Reply #8 on: March 10, 2019, 01:00:32 am »
yep ok I mean 0v and 5v low voltage supply
Offline Brumby
« Reply #9 on: March 10, 2019, 01:22:31 am »
 :-+  That's much better.  Everyone will understand that immediately.
