Author Topic: relay holding current  (Read 1666 times)
Offline LaserTazerPhaserTopic starter
« on: June 03, 2019, 10:53:49 pm »
Datasheet does not depict any holding current. Whats the rule of thumb for these category of relays?
http://www.hongfa.com:8080/pdfjs/web/viewer.html?file=/Uploads/PDF/HF102F_en.pdf&stamp=1559602009559
Offline KMoffett
Re: relay holding current
« Reply #1 on: June 04, 2019, 12:34:16 am »
Take a voltage a little higher than the "drop out voltage" and divide it by the coil resistance.
Ken
The following users thanked this post: LaserTazerPhaser
Offline rfengg
« Reply #2 on: June 04, 2019, 12:49:46 am »
Assuming that you are reducing the current to save on power, ~30% of the nominal operating current should be fine to "hold" the armature of the relay.
30% reduction in the coil current, should give you ~1/10 power savings.
The only downside to this is you cannot operate reliably in this condition if you are in a harsh environment with a lot of vibration and shock to the relay.
Is the relay driven by a DC voltage or is there an option of PWM-ing it?
The currents can be deduced from the voltages on the data sheet divided by the coil resistance.
« Last Edit: June 04, 2019, 12:52:51 am by rfengg »
« Reply #3 on: June 04, 2019, 04:10:08 am »
Going with this 40amp relay http://www.hongfa.com:8080/pdfjs/web/viewer.html?file=/Uploads/PDF/HF165FD-G_en.pdf&stamp=1559625739820 instead as it handles more current. Its going to be powered by either a wall adapter or 12v battery pack series with a SPST series to relay coil since high current SPST switches are far more costly. Its going to switch a 18.5amp adapter into an inductive load
« Last Edit: June 04, 2019, 05:23:17 am by LaserTazerPhaser »
Offline KMoffett
« Reply #4 on: June 05, 2019, 01:46:08 pm »
