Author Topic: sony hd projector  (Read 1821 times)
Offline kevin1Topic starter
sony hd projector
« on: July 27, 2014, 05:19:48 pm »
 HiI have a problem with my sony hd projector, there seems to be a green pixilated blob forming at the side of the image. Ive done some research and think it could be the lcd unit beginning to fail the blob started about 5 pixels wide but it is gradually getting bigger. Any info on cause and how to get it repaired would be appreciated.
Offline German_EE
Re: sony hd projector
« Reply #1 on: July 27, 2014, 05:28:29 pm »
Sorry to be the bearer of bad news but yes, you have an LCD failure. The straight line at the top of your blob is a crack in the LCD.
Warren Buffett
« Reply #2 on: July 27, 2014, 05:40:25 pm »
Thanks for your reply, do you have an idea what it would cost to repair this?
