Author Topic: What's the best way to make a waterproof solder joint?  (Read 295 times)
Offline e1p3dr0
« on: June 22, 2021, 10:54:14 am »
Looking for your techniques on how to make a waterproof solder joint.
I've come across various different ways like liquid tape, self-amalgamating tape, silicone under shrink wrap, but would welcome your experiences.
Offline SuzyC
Re: What's the best way to make a waterproof solder joint?
« Reply #1 on: June 22, 2021, 10:59:21 am »
Solder it. Coat it(optional) with (depending on high voltage/high-low temps/water pressure/flexing/saltwater/chemical environ): silicon grease/superglue --->double heatshrink with (optional)drop of adhesive/silicon grease/superglue under first layer heatshink tubing. Top heatshrink tubing should ~1-cm excess each side end of bottom heatshrink over soldering point.
« Last Edit: June 22, 2021, 11:32:16 am by SuzyC »
The following users thanked this post: e1p3dr0
Online fordem
  • Country: gy
« Reply #2 on: June 22, 2021, 03:29:36 pm »
My preference is marine grade heatshrink tube - this is similar to regular heatshrink tube but has a thicker wall and contains a heat activated adhesive that seals to the wire insulation and soldered joint.  I've also used the self amalgamating tape, but that does not work well on smaller joints.
Offline fourfathom
« Reply #3 on: June 22, 2021, 03:33:35 pm »
A wire-to-wire joint?  Yes, the adhesive-filled heat-shrink.  Marine-grade stuff is available (ANCOR brand, for example), but you can also find it in most hardware stores as it is used when wiring submersible well-pumps.
