Author Topic: Success Prototype 40v 4amp MC1466L power supply Thankyou everyone that helped !  (Read 1104 times)
Offline JwillisTopic starter
It works !!! With a few little tweaks I'll get the output perfect. It's a bit of a mess right now with all the hacks but it works great .Nice sweet current control with a nice 1 milliamp step.Goes to 3.98 amps at max.All the 2N3055,s get warm but not to hot to touch so they're all running at all levels of current .
So far the voltage control works with 1 millivolt step without any problems but will test that further.The final model I'll change out the analog meters for digital ones.
I finally figured out the math to get the values of resistors that get the output amperage of each transistor and balance the ones in parallel.
With this design I can increase amperage output as much as i need but we'll see.
I would like to thank everyone that had offered their input and help.
Here's the schematic ,so far, that works.
Again thank you folks.
The following users thanked this post: MK14, 1001
Offline j2lr
Hello,
I have just finished a laboratory power supply which might interest you !!!....with MC1466L and MJ3001(darlington)
0-20 V 5A
0-50V master 1A
0-50V slave 1A symmetrical
3 multimeter ICL7107
Best regards
Jean-Luc
 Cavan France
The following users thanked this post: 1001
Offline Benta
Just curious: where did you get an MC1466L? I't been obsolete for 40 years.
Offline Dan_Ohm
I like that MC1466!!
Offline j2lr
Hello
I found them here :
https://www.ebay.fr/usr/txhang_fans?_trksid=p2047675.l2559
In sets of 5 : 22€
Best regards
Jean-luc
