Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
What does nB mean as a resistor value?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: What does nB mean as a resistor value? (Read 3873 times)
sajattack
Contributor
Country:
on:
May 26, 2018, 05:27:27 am »
I've modified this design a little and now I'm ready to assemble but I'm not sure what an nB resistor is.
https://easyeda.com/wegi1/sd2iec-1-2-shadowolf
Logged
ataradov
Super Contributor
Country:
Re: What does nB mean as a resistor value?
Reply #1 on:
May 26, 2018, 05:42:45 am »
Looks like do not populate. All the components with value nB are in clusters around optional features.
Normally DNP would be just a note, but EasyEDA may not support this, so they had to put it into value, which is a horrible idea.
Logged
Alex
sajattack
BergRD
sajattack
Contributor
Country:
Reply #2 on:
May 26, 2018, 05:47:15 am »
Ok I was thinking it was either that or a 0 ohm resistor.
Logged
ataradov
Super Contributor
Country:
Reply #3 on:
May 26, 2018, 05:49:20 am »
One of the transistors in also nB, so it can't be 0 Ohm.
Logged
Alex
ElektroQuark
Supporter
Country:
Reply #4 on:
May 26, 2018, 07:21:47 am »
no BOM?
Logged
www.elektroquark.com
EQVideo
Spanish forum
hydrolisk1792
Contributor
Country:
Reply #5 on:
May 28, 2018, 09:55:07 am »
Noting from where it is in the schematic on pin 42 it could be an optional component. Like try it with and without it and see what the best results are.
Logged
dsegel
Contributor
Country:
Reply #6 on:
May 28, 2018, 03:51:02 pm »
If it were nb or Nb I'd guess it meant Nota bene, which usually means there's an explanation somewhere else. Is there any more documentation you could look through?
Logged
BrianHG
Super Contributor
Country:
Reply #7 on:
May 28, 2018, 05:03:00 pm »
On my designs, I use DNP in my BOMs for do not place.
Logged
__________
BrianHG.
https://github.com/BrianHGinc
capt bullshot
Super Contributor
Country:
Reply #8 on:
May 28, 2018, 06:32:58 pm »
That's an German abbreviation: "nicht bestücken"
As others pointed out, it means "do not populate"
Logged
analogo
florentbr
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
