With some algebra, you could design a similar network with an input resistor feeding the junction of two resistors between +5 V supply and 0 V, if the +5 V supply is available.
The Thévenin equivalent of the latter two resistors is equivalent to Berni's suggestion of a resistor to a +2.5325 V bias supply.
You may need a variable resistor element to calibrate this if your +2.5 V offset is critical.
