I have been studying electronics for over a year now, but I've only made low voltage projects.
And now...
I am designing a power supply witch will pulse 550-600 negative volts and 100A, duty cycle 1%-5%. Mains 220V, but I think I can get 3p 480V.
So, I need a capacitor bank, and here is where I am getting all my headaches. I know the theory but in real life there are just to many capacitors
I don't know witch is the best way to accomplish it.
Should I step up the voltage to 600 and use high voltage capacitors in parallel?
Should I step down the voltage and use a Cockcroft–Walton configuration to raise again the V?
Many of you probably have made something similar. Please give me some input on your experiences.
