Author Topic: 74HC14 Circuit Not Working  (Read 27702 times)
Offline ludzinc
    • My Misadventures In Engineering
Re: 74HC14 Circuit Not Working
« Reply #75 on: May 30, 2017, 05:58:17 am »
Can you provide a pic of your layout?
This time don't unplug anything - show us the exact layout you are trying now.
Offline rx8pilot
« Reply #76 on: May 30, 2017, 07:01:06 am »
I doubt the scope is to blame, it just needs to be used correctly. All details as are important which is why more than one person has requested very specific information. You seem to be worried you will be judged on the equipment you have and that is blocking the help you are seeking.
You should be able to make this work with no test equipment at all - a low end scope is a nice bonus.
Sent from my horrible mobile....
Online Zero999
  • 0999
« Reply #77 on: May 30, 2017, 09:46:19 am »
There could also be a problem with the 'scope or probe. Try measuring the resistance of the probe with a multimeter. It should be 1M on the x1 setting and 10M on the x10 setting.
Offline andybarrett1
« Reply #78 on: May 30, 2017, 10:03:06 am »
+1
Offline RyanGTopic starter
« Reply #79 on: May 30, 2017, 06:09:29 pm »
I believe the DSO138 does only 1X mode, and it is built into the board. The probe that it comes with has 0 ohms across it. I tore everything off the breadboard again today and rebuilt the whole circuit for about the 10th time, and it works.
Online Zero999
  • 0999
« Reply #80 on: May 30, 2017, 07:50:32 pm »
Then the probe or 'scope input is broken. 0 Ohms would cause a short circuit and it would behave exactly as you've described.
So is it working with the probe connected now? If it is, then it seems like 'scope or probe has an intermittent short circuit. Try flexing the probe's cable and checking the resistance at the same time. Another possibility is something metallic short circuited the input on the 'scope's PCB.
« Reply #81 on: May 30, 2017, 08:10:27 pm »
It was working while controlling a LED. The scope has 1Mohm built into the board with no switch on the probe. I did not check the circuit with the scope.
Online Zero999
  • 0999
« Reply #82 on: May 30, 2017, 08:15:44 pm »
Well if what you said in the other post above "The probe that it comes with has 0 ohms across it." then you have a problem with the 'scope/probe. I was going to suggest you use another channel but I Googled the DSO138 and it only has one channel so you're SOL.
Offline Nusa
« Reply #83 on: May 30, 2017, 11:31:03 pm »
The "probe" that comes with the DSO138 is literally a short BNC cable with two alligator clips on the other end. However, the BNC output is already compensated and measures about 1MOhm. There are two trimmer caps on the board to calibrate it.
https://youtu.be/F1oDhaqyIvk
« Reply #84 on: May 31, 2017, 01:52:21 am »
That is what I was trying to say. Now that I have this circuit working, somehow, I wanted to know the actual best way to do a PWM signal for the full range of duty cycle from 0%-100% without a micro
Offline StillTrying
  • Country: Broken Britain
« Reply #85 on: May 31, 2017, 10:36:55 am »
I'm amazed that people still think the '14 stuck at 2.4V problem was/is something to do with a scope probe, or a bad scope probe, when I was reproducing it for 2 hours in Reply#57.
https://www.eevblog.com/forum/projects/change-pulse-width-of-a-signal/msg1129000/#msg1129000
If you're not too bothered about the frequency changing a bit many other methods are available.
« Last Edit: May 31, 2017, 10:45:14 am by StillTrying »
Offline stj
« Reply #86 on: May 31, 2017, 11:52:35 am »
2.4v should be impossible, unless it's the average of a very fast squarewave.
a frequency counter or similar function in a multimeter would be handy here.
Offline ebclr
« Reply #87 on: May 31, 2017, 03:15:26 pm »
Duty Cycle from 0%-100 is impossible.
O% and 100% means no oscillation , no cycle  no duty
Online Brumby
« Reply #88 on: May 31, 2017, 03:20:14 pm »
From an oscillator output - I agree.  However, if you wanted to, you could design a circuit that would switch out the oscillator and connect the output to 0V or Vcc - which would effectively give you the 0%-100% range.
You could also program it out of a micro - if you were to include those in your range of chips.
« Reply #89 on: May 31, 2017, 04:05:04 pm »
I understand that 0% and 100% aren't possible with oscillation. As far as the 2.4v thing it was definitely my cheap scope interfering, in my case. I'm sure it can be replicated in other ways.
Offline rdl
« Reply #90 on: May 31, 2017, 07:41:42 pm »
You can get close to 0-100% with a 555 timer as long as you're not too concerned with constant frequency. Dave did this in episode #392 if you haven't seen it.
Online Zero999
  • 0999
« Reply #91 on: May 31, 2017, 10:08:33 pm »
The easiest way I know of to get 0% to 100% PWM, with jellybean parts and no MCU, is to use the LM393.
« Reply #92 on: June 01, 2017, 10:21:42 pm »
This may not be the simplest way of doing it, but does this look like it would work? It works in everycircuit.
http://everycircuit.com/circuit/6706632576991232
I think it will only show in Chrome
Online MK14
« Reply #93 on: June 01, 2017, 10:26:54 pm »
No, not apparently showing in Chrome.
Ideally, it would be nice if you can post circuits in some kind of standardized format. E.g. image files.
Something which needs to go onto a weird website and/or needs downloading executables is not a good idea, for easy viewing on forums.
Something went wrong...
Verify that native client is enabled:
    1. Type about:flags in the Chrome address bar and enable native client
    2. Type about:plugins in the Chrome address bar and enable native client
Try to refresh the page or report to info@everycircuit.com
(Load error: NaCl module load failed: PnaclCoordinator: pexe load failed (pp_error=-2).)
« Last Edit: June 01, 2017, 10:29:43 pm by MK14 »
Offline rdl
« Reply #94 on: June 01, 2017, 10:33:18 pm »
I had this in my notebook from a long time back. I didn't have time to build it again to test until today. It works okay and you may already have the parts. With a 10k pot and 0.1 uf cap I got from less than 1% to over 99% duty cycle at about 650 - 925 Hz.
« Reply #95 on: June 01, 2017, 10:35:44 pm »
I thought that the website I posted worked in chrome no matter what. I sent it to other people to check. Here is the picture.
The following users thanked this post: MK14
Offline StillTrying
« Reply #96 on: June 01, 2017, 10:44:17 pm »
That can't be right.
Edity: The first inverter and resistor don't make sense.
Edity2: Is the value of R1 critical.  :)
« Last Edit: June 02, 2017, 01:07:21 am by StillTrying »
Offline rdl
« Reply #97 on: June 01, 2017, 11:18:50 pm »
It's not my circuit just one I found. Maybe I drew it wrong, but I ripped it up and built it again and it still works. Maybe someone else could give it a try? It's pretty simple and quick to build. Sorry for the poor quality image.
Offline rdl
« Reply #98 on: June 02, 2017, 02:39:28 am »
1. I drew the circuit close to the way I originally built it on perfboard so it doesn't look the way it's usually shown.
2. The original circuit used a 4049 and I have R1 noted as "improves shape of square wave - use about 10x value of R2"
Maybe it's the different chip, but R1 seems to make little difference here. As a matter of fact, at higher values and with small values of C1 and R2, it causes the output to become a sine wave at around 10 times higher frequency than expected. The circuit seems to work fine without it and just a wire directly to the input of the first inverter.
Offline BrianHG
« Reply #99 on: June 02, 2017, 03:15:21 am »
In that schematic, shouldn't R1 be between the diodes and cap with the cap wired direct to the first inverter input.  Otherwise, when your trimpot is wired all the way to one side or the other, that circuit's output will sort of be short driving the cap distorting the second inverter's output when the trimpot is set to 0% or 100%.
