The "ground" pin is actually an input, being the reference voltage for logic low on the switching input. The actual switches, level shifter, and switch driver operate between the positive and negative voltages, so that a ground-referenced logic input can switch an analog signal that goes both sides of ground, up to the levels specified in the datasheet.
