Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
7555 PWM wrong behaviour
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: 7555 PWM wrong behaviour (Read 3881 times)
m.m.m
Regular Contributor
Country:
EE MSc Student and Hobbyist
on:
April 18, 2015, 06:19:21 pm »
Hi, I've made a 7555 pwm generator from
schematic and it worked well on the breadboard but it doesn't work well on the PCB when soldered. when I adjust the potentiometer the fan at first is at full speed and then when the potentiometer is on the half way it's on low speed and when it's on the other end it's again at full speed. what should I do?
thanks a lot.
Logged
25 y/o Electronics Lover
Simon
Global Moderator
Country:
Did that just blow up? No? might work after all !!
Re: 7555 PWM wrong behaviour
Reply #1 on:
April 18, 2015, 06:27:33 pm »
check your diodes orientation sounds like they are both the same way round.
Logged
TerminalJack505
Super Contributor
Country:
Reply #2 on:
April 18, 2015, 06:41:00 pm »
Check to see if you swapped a couple of the wires on the pot as well.
Logged
m.m.m
Regular Contributor
Country:
Reply #3 on:
April 19, 2015, 07:12:58 pm »
no, the diodes are OK and I replaced the potentiometer but no sense.
this pic might make sense.
thanks
Logged
Simon
Global Moderator
Country:
Reply #4 on:
April 19, 2015, 07:21:15 pm »
Check your bread board very carefully maybe with a multimeter to check that all the tracks that need to be brocken are brocken and that there are no invisible solder bridges.
Logged
m.m.m
Regular Contributor
Country:
Reply #5 on:
April 20, 2015, 06:56:09 pm »
I checked the resistance between the two not-moving terminals of the potentiometer (i.e. the resistance of the whole potentiometer) and it was about 6k, but it should be around 80~100kOHM. It's definitely the diodes, and when I pull the potentiometer off it's place in the circuit it's resistance gets back to normal. And the resistance around the variable terminal of the potentiometer is about 20k when the knob is at the middle and around 10 ohms when it's on the ends of the potentiometer (even in the other end of the potentiometer where it should be around its maximum value).
BTW I used 1N5819 diodes (as suggested in
this link
Logged
Simon
Global Moderator
Country:
Reply #6 on:
April 20, 2015, 07:40:46 pm »
if it's a 100K pot and half way it measures 20K it could be a log one, what is the resistance in the place of the potentiometer, if you think the diodes are affecting the result then reverse the meter probes
Logged
m.m.m
Regular Contributor
Country:
Reply #7 on:
April 21, 2015, 01:24:13 pm »
no, it's not log scale, it's 50kOhm when not in circuit when the knob's half way, reversing the probes makes no sense (maybe because there is two diodes in both directions).
Last Edit: April 21, 2015, 03:17:01 pm by m.m.m
Logged
m.m.m
Regular Contributor
Country:
Reply #8 on:
April 21, 2015, 06:18:40 pm »
the problem was with the diodes, they were soldered like parallel but the had to be like series.
my bad, sorry.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
