I have an old quartz crystal with the frequency 76.8 KHz.
I want to build a simple sinusoidal oscillator with it using MOSFETS (I have some 2N7000 for this project)
Please help me with a circuit diagram.
I don't find anything useful after searching on Internet.
If it's actually an old crystal, in a large, flat metal can, look for 100kHz crystal oscillator schematics - close enough.
(If instead it's a tiny cylinder, look for 32kHz schematics instead.)
You will find some circuits using bipolar transistors... they can be adapted to 2N7000s... you may need to adjust the biasing. It's probably better just to buy some bipolar transistors though.
There is no such thing as a "simple sinusoidal oscillator". To get a good sine wave, you need AGC, which is not really simple.
As a compromise, you can take the oscillator output from the output side of the crystal (usually using an emitter/source follower so as not to load it). That waveform is filtered by the crystal, so it is close to a sine wave.
