Author Topic: _ _ _ possible 100khz SINE osc for ESR ? _ _ _  (Read 2172 times)
Offline 3roomlabTopic starter
« on: March 23, 2014, 04:17:49 pm »
not sure where to post this, but probably somebody have already gotten their head around to this kind of oscillator. i have not used it before, any one tried a oscillator like this before for their ESR? just happened to be diggin around and happened to pop my head in the simulator to try this version.
(if you have tried this on a breadboard, do post a pic) :D
Re: _ _ _ possible 100khz SINE osc for ESR ? _ _ _
« Reply #1 on: March 23, 2014, 04:32:28 pm »
Phase shift oscillator. Each section has 60 degrees ( or pretty close) of phase shift and this combined with having enough gain to exceed unity through the loop makes an oscillator. Has poor stability, and is sensitive ( and non linear as well) to both supply voltage, temperature and component aging. Can be difficult to start at times with particular component values, but can be made to work. Do not expect a sine wave out of it unless filtered. Having the capacitors like that makes it very noisy as it amplifies harmonics quite well.
