Author Topic: printer 110 to 220 volt  (Read 1552 times)
Offline firasTopic starter
  • Country: ae
« on: March 01, 2018, 01:01:32 pm »
i have hp printer 4350 (board rm1-1173)
printer 127 volt work i need change to 220 volt can  you help me
Offline Paul Price
Re: printer 110 to 220 volt
« Reply #1 on: March 01, 2018, 10:04:19 pm »
Printers are so cheap to buy. It would be costly in time and money to modify the P/S to work at 220v. Quite complicated. It is much more easier and would cost less to just buy a 220V model.
However,  I notice most HP printers that are shipped with 120V power cords are also capable to run at 220V  using a different power cord. You can try this and either your printer will either immediately emit smoke and you will hear a loud pop..or else work perfectly.
Offline helius
« Reply #2 on: March 01, 2018, 10:51:16 pm »
Offline Paul Price
« Reply #3 on: March 01, 2018, 11:36:29 pm »
If you are really interested in using this printer you might find a 220V to 120V converting mains transformer as a solution option. A replacement OEM P/S would cost at least USD $70, but a stepdown transformer requires no installation.
Offline Brumby
« Reply #4 on: March 01, 2018, 11:38:33 pm »
You want the quick and easy answer....?
Yep.
Have a look at this sort of thing: https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Delectronics&field-keywords=240+volt+step+down+transformer+2000w
These come in various capacities, but just make sure you get one that is at least "rated" 50% higher than the printer draws.  Personally, I'd go double.  For the 4350 I have found a figure of 790W - so I'd be looking at something with at least a 1500W rating.  2000W seems to be the commonly available figure.  Always go high here ... it adds a safety margin.
Also - such a unit is self contained and universal.  If the printer gets replaced, you could use the transformer for something else ... or sell it.
« Last Edit: March 01, 2018, 11:45:46 pm by Brumby »
