Author Topic: A capacitor of 5mF is ok for this type of circuit?  (Read 1445 times)
Offline bonzerTopic starter
« on: January 05, 2019, 10:47:49 pm »
Hello everyone! Please tell me if you think this is a bad idea. Having a circuit like this with resistors of value about 10kOhm and the second capacitor 300nF. It feels like that 5mF capacitor is too big but I don't know. For that frequency of operation, do they even exist non electrolytic or non polar like ceramic with good frequency response? Would they cost too much? Is this anyway possible? I don't have to implement it practically but anyway I would like to know what are the disadvantages, a part from maybe big dimensions. If it's a huge problem I could anyway solve it by changing some resistor values but please let me know what you think.
« Last Edit: January 05, 2019, 10:50:12 pm by bonzer »
Offline Zero999
  • 0999
Re: A capacitor of 5mF is ok for this type of circuit?
« Reply #1 on: January 05, 2019, 10:58:28 pm »
10kHz is not a high frequency.
Presumably you mean 0.005F, by 5mF, not 5µF.
Why not make it DC coupled? 5mF and 10k is a time constant of 50s, so it will take around 10 minutes for the DC bias point to be reached.
« Reply #2 on: January 05, 2019, 11:18:41 pm »
Oh thanks! I didn't think about it. So it's also a problem in DC.
Offline M4trix
  • Country: hr
« Reply #3 on: January 05, 2019, 11:30:10 pm »
Good luck finding a 5µF capacitor.  ;)
Offline Audioguru
« Reply #4 on: January 05, 2019, 11:35:32 pm »
5mF is 5 milli Farads which is 5000 micro Farads that is HUGE! A 1uF film capacitor will produce a -3dB cutoff frequency at 16Hz.
Why do you want a peak of more than 10000 times at about 15kHz? When the input is only 5mV peak which is almost nothing then the output will try to be more than 50V peak.
Here is a simulation with a 1uF input capacitor:
Offline Zero999
  • 0999
« Reply #5 on: January 06, 2019, 08:52:41 am »
Use the nearest E6 value, which is 4.7µF or if non-polarised is really required, two 10µF back-to-back.
I didn't mention this in my previous post, because I'm not convinced a non-polarised capacitor is necessary.
« Reply #6 on: January 06, 2019, 02:57:19 pm »
Thanks for your answers. Well you convinced me that it's not the case. I will try to change some resistors.  I also noticed later that it anyway doesn't do what I was looking for (it introduced me the first zero at higher frequency while I wanted the first zero to be in the origin.)
