In the attached circuit C1 and C2 are 470pF for the MF version. I built the LF version and used polypropylene caps, easily found in 1nF value. I am building the MF version now, and I do not have poly caps in 470pF, is there any reason not to use ceramic through hole caps there, at 470pF? Thanks.
