Howdy folks,
Old fart here, but very much a “young player” when it comes to hardware (been a software guy all my life). I’m looking for some guidance when it comes to earthing. I’ve been reading up on different types of grounds and, while I’m now somewhat the wiser, there are a few things I still can’t quite figure out.
BackgroundI’m going to upgrade from my little Antex fixed temperature soldering iron to one of those cheap and nasty YiHUA 936 clones. I’m not expecting it to last very long but it will serve my purposes (and suit my tight budget) for a little while at least.
When the YiHUA quits it’s my intention to replace the guts of it with a circuit I found online at
http://www.zl2pd.com/SolderingStation.html - more specifically the version shown in this schematic
http://www.zl2pd.com/img/SolderingStation/ATtinyBasicCct.gif. As shown the controller is driven by a 24V 3A laptop power brick. My intention is to add a rectifier and suitable smoothing capacitor to the original YiHUA transformer to provide me with 24V DC Power.
QuestionsIn the above schematic, the tip of the iron is grounded to the circuit ground rather than to earth. In both the YiHUA and the original Hakko 936 the tip is grounded to earth and not to the circuit ground. I assume that this is purely to provide some level of ESD safety.
1: Does connecting the tip to the circuit ground alone provide any ESD safety at all or does it need to be connected to earth?2: If it has to be the connected to earth purely for ESD safety, do I really need it as a basic hobbyist or can I do without it? (I have seen a lot of conflicting opinions about this)Note that in everyday life I have virtually zero problem with static - possibly because I live in Northern Ireland, so humidity is always high, and the fact that the flooring, workbench etc. are all wooden.
The one modification I was hoping to make to this circuit as it stands was to remove the ‘Standby’ switch and connect pin 3 to one of my metal soldering iron stands. This would mean that when the iron was placed in the stand and touched the metal, the pin would be grounded and standby mode enabled by the code in the ATTiny.
3: If the tip needs to be connected to earth rather than circuit ground, would this still work (i.e. in this case would earth function as circuit ground and trip standby mode)?4: If not, is it possible/safe/desirable in this case to connect the circuit ground to earth to make it work?Thanks in advance for any help you can provide, and remember, I did warn you I was a newbie at the top of the post
Setanta
