Author Topic: A Ic that acts as a Controlled buffer?  (Read 872 times)
Offline ThePeoplesLabTopic starter
    • The People's Lab
« on: October 20, 2018, 05:35:52 am »
Hi All I'm looking for a Ic that can take in a single 5v input to allow ~2 (or more) separate data lines to connect. Is there an Ic for this I have yet to find one,if not does anyone have a solution for me? I'm looking to switch a rx and tx line from a chip to 2 different sources with only one switch per source, (ie, Switch one connects them to the Usb converter chip, Switch two connects it to a different chip)   Thank you all!!   - Tavian
« Last Edit: October 20, 2018, 05:37:49 am by ThePeoplesLab »
Re: A Ic that acts as a Controlled buffer?
« Reply #1 on: October 20, 2018, 06:39:53 am »
The following users thanked this post: ThePeoplesLab
    • The People's Lab
« Reply #2 on: October 20, 2018, 06:56:06 am »
That works Perfectly!!! Thank you!
