My PC set up only requires 6 at most.
2 LCDs (soon to be 3) PC and Amp. Two of the screens can even share a Y split IEC cable.
The main plug concern is for the TV/home theatre part. Which is where I'm going to be using the two 8 way boards for a total of 16 sockets with two (or more) spare on the power strip coming off the extension lead.
I have 17 devices that I want to plug in so I don't have to be messing around with cables all the time. There are only a few devices out of that 17 that pull more than 100w and I'll only be using 3 or so at once.
I think that's what I'll ultimately end up doing now
As for talking to the landlord about a new point, I don't think it's worth the hassle as most agents are useless and don't even write stuff down haha
Plus the wall I would like a point on is cement and all the others are that old horse hair plaster that crumbles if you look at it funny haha
I'm planning on installing a window mount air con and will save my chances with the landlord for that hehe
Thanks (still open to better suggestions
