Author Topic: A load off my mnd  (Read 3116 times)
Offline PerranOakTopic starter
A load off my mnd
« on: January 25, 2019, 03:14:50 pm »
I'd like to make an electronic load. Something simple with modest parameters, say, up to 1A and 25V or so.
Any recommendations for a nice circuit that you may have seen?
Thanks.
You can release yourself but the only way to go is down!
RJD
Offline JackJones
Re: A load off my mnd
« Reply #1 on: January 25, 2019, 03:45:27 pm »
There is the eevblog DC load, about as simple as you can get:
If you want something a little bit fancier, this Scullcom DC load is pretty good, highly recommend watching the videos.
The following users thanked this post: PerranOak
« Reply #2 on: January 26, 2019, 02:56:51 pm »
Brilliant! Cheers and thank you.
RJD
Offline JackJones
« Reply #3 on: January 26, 2019, 03:17:25 pm »
I have built both of those DC loads, in fact I think the eevblog version was one of my first projects. I think it might have been oscillating though, I remember hearing a buzzing sound coming from it at higher currents. Next time I powered it up it was dead. I didn't have a scope back then so couldn't check. Might make sense to put a series resistor to the gate and/or a snubber from the opamp output to the opamp negative input if you're going for the simpler design.
I also built the Scullcom version with minor modifications, like some different component choices and used a micro for it. I'm not a big fan of using Arduinos permanently in projects, it's much more professional to just use a micro. Nothing wrong with it though.
I'd suggest watching the whole series of the Scullcom videos if you go that route, because he does add quite a bit of functionality to the design over the videos.
Offline MarkF
« Reply #4 on: January 26, 2019, 04:09:55 pm »
Here is mine.  For low currents you can get away without a fan.
Edit:  Updated circuit
« Last Edit: June 04, 2022, 01:24:21 am by MarkF »
The following users thanked this post: spec
Offline rdl
« Reply #5 on: January 26, 2019, 04:23:16 pm »
The EEVblog version is worth looking at as a start. It's pretty simple and easy to build, but it usually oscillates. That's easily fixed as long as you have an oscilloscope to see what it's doing.
« Reply #6 on: January 29, 2019, 02:52:11 pm »
"Loads" to look at, thanks.
RJD
