Author Topic: A mosfet, a dif comparator, a bridge rectifier, and an inductor walk into a bar.  (Read 1131 times)
Offline BeaminTopic starter
  • If you think my Boobs are big you should see my ba
A mosfet, a diff. comparator, a bridge rectifier, and an inductor walk into a bar where they talk to a BC557 and a BC547 a big cap and some resistors.
What would you call this thing? I don't remember building it. My guess from the fact it has 4 leads two are "AC" and one is cat. and an. that it's a regulator or tiny power supply.
Will it mess it up if I put DC to it? How would I know how much voltage it takes? It has no part numbers on the board. Certainly it can't take mains power could it? Why else would you have A/C inputs unless it's supposed to work with a transformer.
What does the comparator do? I haven't seen that in a power supply. Is it so it can adjust a range of voltages and still stay at the output? To find voltage do you look at how much this IC can handle then trace out resistor that goes to it?
Max characters: 300; characters remaining: 191
Images in your signature must be no greater than 500x25 pixels
Offline pyroesp
    • Nicolas Electronics
It's a 1W/3W power LED driver.
It's a Velleman kit, 2 sec google search : https://www.velleman.eu/downloads/0/illustrated/illustrated_assembly_manual_k8071_rev1.pdf
I looked at their kits and didn't see this one. But I suck at seeing though.
