Author Topic: A power bank still detects a connected device if I disconnect USB's VBUS  (Read 1197 times)
Offline epigramxTopic starter
Do you know of a way to do it - in a standard way - without disconnecting the entire cable? Would disconnecting only GND do it (will try that next if no one answers)?
PS. In case anyone wonders why, it's because I can't change the power bank's model/brand and it doesn't fast-charge itself, if anything else is connected to it.
Offline malagas_on_fire
  • Country: pt
  • Kernel Panic
    • Malagas Lair
If one can make knowledge flow than it will go from negative to positve , for real
Offline amyk
It senses the data lines too.
Another forum suggested to just switch the GND because it will make the other pins float. I guess I'll try that next.
what about a cable with a built-in switch
I'd rather avoid that due to cost and space. Plus, it probably only does what I already do (since it's called "power cable").
success, dangling GND made the power bank completely oblivious anything is connected to it.
Offline bson
The host doesn't care if a device is attached to Vbus or not.  What it detects is pullups on the data lines.
The following users thanked this post: wraper
So I guess it detects a specific range of resistance between GND and D+ or/and D-.
« Last Edit: March 13, 2019, 06:45:18 am by epigramx »
Offline bson
Depends; different pullups indicate different speed... so the pullups are used to both detect the presence of a device and its speed.
For USB 2, a 1.5k pullup on D+ to +3.3-5V indicates Full Speed.
A 1.5k pullup on D- indicates Low Speed.
A high speed device connects as FS and then goes through a special reset cycle (a chirp) to bump the speed to HS.
Since this is only a charger in effect (a power bank) I guess it only detects anything in that range.
If they are floating, I assume it considers it higher than that impedance. Correct me if I'm wrong.
update: It's Quick Charge 2.0 compliant so it does deal with D+/D- actively.
« Last Edit: March 13, 2019, 07:01:59 am by epigramx »
