I'm in the US...Kentucky, if that makes a difference.
Thanks for the response, and especially for the link to Franky's eBay store. I had heard his name mentioned for these type of items in my previous searches on the subject, but nobody provided a link in the threads I found. His prices are reasonable enough for me to buy several items to get me started, then build on that as I need certain components. What I was really looking for is some sort of starter kit that had the basics that I could build from, but one large order will get me to the same end.
All the brands make kits you can build from. Just pay close attention to the connectors (straight banana, stackable banana, retractable banana, right angle banana, ..., if it threads onto a probe, ...).
Personally, I use Probemaster as they offer more value than Fluke or Pomona IMHO (i.e. little more stuff in the kit than either of the others for a little less money). Quality is top notch, not junk. 9000 series kits have more in them than the 8000 kits. The way the accessories attach to the different series is different as well. For the 8000 series, everything threads onto to the end of a probe (can be an issue with electronics IME, due to the added weight of the probe, such as not staying attached to the test point). 9000 series is all plug-in via banana's.
If you prefer to make it all yourself, feel free. You get exactly what you want. But there will be things you won't be able to make, such as the ends that would plug onto banana's (incl. retractable versions), such as alligator clips, ... types of things (plugs directly into the end of the lead <just wire, not on the end of the probe's tip>).
Take a look at the manufacturer's sites, and pay close attention to the pics and descriptions. You'll be able to tell what I'm talking about.
