Author Topic: non polarised capacitors  (Read 2860 times)
Offline M0BSWTopic starter
  • Left this site 2013, they will not delete it ????
« on: February 02, 2014, 08:08:32 pm »
Hi, I need a non polarised electrolytic capacitor, and I'm in a bit of a pinch, I remember that there is a way of wiring two polarised caps to make a no polarised cap, but I can't for the life of me remember how to do it , can anyone help.
no one would or will tell me how to delete this account
Re: non polarised capacitors
« Reply #1 on: February 02, 2014, 08:10:55 pm »
Back to back in series same value.
« Reply #2 on: February 02, 2014, 08:24:47 pm »
It is just to try something out , before buying a non polarised cap, as the thought of one of them degrading wouldn't be good.
Offline The Electrician
« Reply #3 on: February 03, 2014, 12:21:12 am »
What's the application?  Will the voltage across the NP cap have a substantial DC component for any length of time?
« Reply #4 on: February 03, 2014, 07:37:16 am »
I don't think so, I'm using them as a part of a noise filter at the speaker end on a receiver.  the output is around 3 watts into a 8ohm speaker. This is the basic circuit.
« Last Edit: February 03, 2014, 05:56:13 pm by M0BSW »
Offline Mr Smiley
« Reply #5 on: February 06, 2014, 03:03:27 am »
From a pdf document i got some from where i can't rememter  :-/O
If two, same-value, aluminum electrolytic capacitors are
connected in series, back-to-back with the positive termi-
nals or the negative terminals connected, the resulting sin-
gle capacitor is a non-polar capacitor with half the capaci-
tance to either of the original pair. The two capacitors recti-
fy the applied voltage and act as if they had been bypassed
by diodes. When voltage is applied, the correct-polarity
capacitor gets the full voltage.
There is enough on this planet to sustain mans needs. There will never be enough on this planet to sustain mans greed.
