So, just put the remaining resistance required in the series circuit between the battery and the 121 ohm resistor.
For example, if you have a 9 V battery, and you want 10 mA through the LED, and the LED has a 2 V forward voltage at that current (read the datasheet for real value), you have a total of (9 - 2) = 7 V across the resistors, of which 1.21 V is across the 121 ohm resistor, leaving 5.79 V for the extra resistor, which would be 5.79/0.01 = 579 ohms.
