Hello sir Kleinstein,
Thank you to your suggestion.
I think, if you look the opamps inverting and non-inverting inputs, it should have some differences.
If we remove lower portion of R3's wire, that means the input difference will be more, that will cause unbalance situation on bottom IC's output.
R3 can make a difference(connected with both output) and taking another reference from same bottom output.
