Author Topic: Linear Technology LT1963 1.5A LDO - Output current no more than 100mA!  (Read 4278 times)
Offline hggTopic starter
  • Country: gr
Re: Linear Technology LT1963 1.5A LDO - Output current no more than 100mA!
« Reply #25 on: April 08, 2019, 10:09:07 am »
Sweet!  :-+
  • Country: gr
The problem was too weird to wait for the breadboard to arrive and I soldered
everything on a breadboard layout PCB I had.   PROBLEM SOLVED!
Psi you were right again.
For the love of God, never ever buy a chinesium breadboard again!
You will forget what you already know..
Thanks guys.
« Reply #27 on: April 08, 2019, 12:23:26 pm »
Worth reading this through as a review: http://www.mit.edu/~6.331/an47fa.pdf
AN47-24 onwards on ground planes and breadboarding.
While that looks like it works now, it depends on the load. LDOs are rather tetchy and can break out into oscillation.
  • Country: gr
« Reply #28 on: April 08, 2019, 02:11:54 pm »
I've tested it up to 1.2A and its stable, no problems.
Thanks for the link.  I will have a look.
