Author Topic: Can't identify an IC SFC2741DC  (Read 4695 times)
Offline AndrewveeTopic starter
« on: January 10, 2015, 09:30:10 am »
Hi all,
I hope someone has seen this before!
I'm repairing a guitar amp for a friend and I can't identify an IC on the board!
The part number (actually all the text) as follows:
SFC2741DC
7837 (I think this may be a date code)
I think its an op amp. I'm trying to find a modern equivalent.
I think a LM741CN would work, but I would like a few more opinions from your respective selves!
Also, its a Carlsbro Hornet amp circa 1970's vintage.
Thank you!
« Last Edit: January 10, 2015, 10:00:25 am by Andrewvee »
Offline sdg
Re: Can't identify an IC SFC2741DC
« Reply #1 on: January 10, 2015, 11:57:00 am »
SFC2741DC
You're kidding or you've never heard of Google ?
 -sdg
« Reply #2 on: January 10, 2015, 12:56:49 pm »
Do you think I haven't tried? Its an old obsolete IC. Can you find the data sheet?
Offline rdl
« Reply #3 on: January 10, 2015, 02:04:15 pm »
Google seems to indicate it's an op amp made by American MicroSemiconductor. It's probably just a 741 clone or knock-off.
Offline sdg
« Reply #4 on: January 10, 2015, 02:06:17 pm »
 :palm:
Google "SFC2741DC", first hit: www.datasheetarchive.com/SFC2741DC-datasheet.html...
The first pdf says all that's needed. And if that's not enough for you, the 3rd pdf on the page lists possible replacements.
 -sdg
« Reply #5 on: January 10, 2015, 10:37:47 pm »
Thank you all. Much appreciated. I'm a novice and wasn't sure if that 3rd datasheet was as you said it was.
Thanks again
