Sounds like just a transformer.
You can always test with an LED and a 1K resistor. If the LED lights up no matter which way it is plugged in you have AC current.
That will work but beware most LEDs are only rated to 5V or so in the reverse direction, but I think some of that is just arse covering on the data sheets.
In my experience, red, orange, yellow and greenish yellow will non-destructively breakdown at around 20V or so and conduct in the reverse direction, but pure green, cyan, blue and white LEDs can be damaged by too higher reverse voltage.
The safest thing to do is to use two LEDs connected back-to-back. If it's AC they'll both light, otherwise only one connected in the correct polarity will light.
In this case, it's definitely AC, because the meter measures 0V on the DC settling and the expected voltage when set to AC. It can be used to power an op-amp circuit with a bridge rectifier and smoothing capacitor.
