Unless you can find a photo that shows the part numbers of the bridge rectifier (under the heatsink furthest from the input connector above the two common mode chokes) and of QW1 and QW2 (under the biggest heatsink) which appear to be the PFC circuit switching transistors, and can identify the PFC controller (I suspect U301) which is in the same general area on the bottom of the board, so you can check its datasheet suggests its suitable for 230V applications, and reverse engineer the PFC circuit far enough to check resistor values and semiconductor voltage ratings are appropriate for 230V input, you can't be *CERTAIN*. However as TimFox points out, a 620V breakdown MOV would offer little if any protection to semiconductors that had too low a voltage rating for 230V input.
