True a resistor will drop voltage a little, and drop inrush surge a lot. The 15 minute cycle is close to what is used to stress test lamps, though most manufacturers use a 15min off 2 hours on cycle for life testing purposes, and test a batch of 100 or so each time, stopping at around 50% failure rate for lifetime. Longest lasting lamps will do the 1000 hour rating with under 10% failure, but the cheap ones will have 50% at this point, with probably 10% failing in the first 100 hours from poor manufacturing.
I bought ( not by choice) a batch of Chinese made downlighter MR16 lamps, and they are very poor, having a running life of less than rated ( 2000H) by far, most only lasting a month in service. Ironically other lamps on the same transformer, next to them are probably 2 years in the same service, and are still working perfectly, only the odd random failure. Some have done 5 years or more. The difference between Osram, Phillips as the good ones, and GE and Radiant as the poor ones, in order of lifetime. The supplier blames the fitting for the poor lamp life.....
