What happens if a ~100v..240v AC switch mode power supply input is connected directly to DC voltage?
- chances of DC voltage arcing in the inputs of the SMPS ?
No.
- components before the diode bridge that would be damaged with a DC voltage?
No.
- SMPS controller chip to be unstable/damaged because too low voltage in its input ?
- stuff that I am not thinking about?
Why would the voltage be lower unless you make it so? Most power supplies are intended to operate with about 340 volts DC produced by the input rectifier and filter. Power supplies which use active power factor correction should operate correctly with DC inputs from somewhat lower than 170 (90 volts?) to 340 volts DC.
If the voltage is too low, then the negative resistance input characteristic of the switching power supply will draw excessive current and damage the power supply. Good power supplies have an under-voltage lockout to prevent this.
Some designs with power factor correction are just defective and will not operate on DC at all because they are expecting AC.
- Without actually connecting it, is there some math to calculate its efficiency ?
The change in efficiency will be negligible.
