Hi, I need a little advice about AC output current of transformer. So here is my setup:
Got transformer with output 24VAC 6,7A (160VA). Iam not sure of anything in AC circuits, not designed anything in AC circuit. But now I plan to build simple linear DC power supply and have to determine how much power can I draw from that transformer for long time without burning it.
So, I put bridge and 3x2200uF capacitors at the secondary. Loaded that setup with dummy load at 5A. Uni-T and clamp meter are measuring AC current before bridge rectifier, Aneng measure DC voltage on capacitors and "oscilloscope" measure DC voltage ripple at capacitors.
Clamp meter says 8,37A of AC current and Uni-T 7,51A. And ripple is very high, more capacitors did not change the game so much. My maximum output voltage after stabilisation will be at the lowest point of the ripple, that is not problem, but problem is that AC current before bridge rectifier. Iam not sure what maximum DC current can I draw after bridge and capacitors without burning out the transformer coil in long operation time.
Thank you for your advice and help!
