Hi Everyone.
I'm building a simple circuit but don't have the necessary 22k resistor. I'm waiting for one to be delivered and in the mean time I was thinking about using resistors I do have (in series) to make up the 22k resistance I need. In this case I would require 4 resistors.
But here's my question. If I wanted to use resistors in parallel, to achieve the same 22k resistance, what calculation would I use?
I have seen calculations to add up resistors in parallel but I need to work backwards, starting with 22k. Hopefully the calculation would give 22k or something close, meaning I could get away with using less than 4 resistors as I would if I connected them in series.
Thanks for any help
W
