I am trying to finalize the AC voltage and current measurement circuit using a differential amplifier. I have designed two circuits for each. In the high side current measurement circuit 2 and voltage measurement circuit 2, I have connected multiple resistors in series to the inputs of the op-amp. However, in the high side current measurement circuit 1 and voltage measurement circuit 1, I have connected a single resistor to the inputs of the op-amp. I am planning to use 0603 package resistors. As I know that op-amps have very high input impedance, I used a single input resistor in circuit 1. I am confused about which circuit to follow for voltage and current measurement, respectively.
