Hi all,
I want to use this mosfet driver with arduino or other 5V logic IC to driver IRF150 or IRF510. However, once I apply the signal, nothing happen like there is no input signal at all and I can see clearly with oscilloscope the pwm signal is working fine while the output is maintained at the applied voltage.
is there something wrong or the IC is burnt ?
note: I connected the output directly without any resistor or capacitors
