Author Topic: Need parts suggestions for a computer fan type air circ system  (Read 2794 times)
Offline bradleyheathhaysTopic starter
I'm designing a small air circulation system (not computer related) where I need to use two computer type fans and some type of fan speed controller, and I need some advice on what parts to get.
Requirements for the fan..
      - 120 or 140 mm
      - as quiet as possible
      - moves as much air as possible (hopefully in the 70+ cfm range)
      - ball bearings, not sleeve
I've done some looking around on newegg, etc and found some good candidates, but if anyone knows of a good brand that's long lived, quiet and moves lots of air please let me know.
And as far as supply power and the speed controller are concerned, I'm entirely open to your ideas.  Being a novice I'm guessing there are probably better parts suggestions that what I've imagined so far.  The power will be coming from 110v so I'm gonna have to convert that somehow.  I have a janky little adapter box that plugs into a 110v outlet and outputs to a female 12v car adapter, so that would probably work.  Although I'd like a more solid electrical connection than the male in female socket of this adapter would provide.
And for the controller I'm thinking a simple light dimmer from home depot might do the trick.
Thanks for helping, I'm all ears.
« Last Edit: March 30, 2017, 06:21:15 pm by bradleyheathhays »
Offline james_s
Re: Need parts suggestions for a computer fan type air circ system
« Reply #1 on: March 31, 2017, 08:33:52 pm »
Any random 12VDC "wall wart" or cord lump style power brick will work fine, so long as it's rated for at least as much current as the fans draw. You can get these for peanuts at thrift stores or garage sales if you don't already have some.
You'll definitely want a PWM speed controller for the DC side, you can buy them ready made or you could build something yourself. If you look on ebay or alliexpress you'll probably find a selection of different inexpensive modules that will do what you need. The Chinese are quite good at coming up with handy little electronic modules.
Offline BurningTantalum
« Reply #2 on: April 01, 2017, 03:54:14 am »
Be aware that the PC type axial fans are not good at shifting air in ducts, so it may be an idea to lash up the system running flat out to check the operation. Centrifugal type fans provide much higher pressure to move air through a resistive duct. I'm not sure how much space you have for installation but maybe a unit from a cooker extractor could be useful. It would certainly be of better quality and longevity.
BT
