You can use a 10k pot where the 5k pot is shown; it will just give reduced sensitivity on the control. If you like you could put a fixed 10k resistor between the wiper and the top of the pot in parallel with the variable resistance. That will change the range back to 5k at the cost of some linearity, but if the pot is originally a log pot it might not be too bad. You'd have to experiment and see what you find more acceptable.
