Author Topic: plcc32 flashing tools  (Read 586 times)
Offline DominoTopic starter
  • Country: af
« on: September 03, 2022, 11:36:41 am »
hi,
one of my managed switches has a broken gui ("application checksum error .... press key to erase...")
according to jtag feedback, erasing and reflashing seems to work but i still end up with the same "FlashCheck Error"
what i noticed is that the IP address of the switch is not the default one.
if i assume that the flashing would also clear any custom settings then i should conclude the flashing did not work at all
flash = 39VF040 (4Mb 2.7-3.6V parallel flash plcc32)
money is not really a problem so i could get a tl866II and a plcc32 socket
but since i wont use it alot i am open for other (DIY?) suggestions
i found some posts about a program called flashrom. with this you could probably reprogram some chips in specific hardware
meaning if i could find a compatible device with plcc32 i could theoretically use that
ps:i digged around and there are a ton of devices but hardly any site listing a comparison
(XGecu?) TL866II (65E) 40pin socket
Xgecu  T48   (75E) 40pin socket
Xgecu  T56  (175E) 56pin socket
V850E2      (50E)
CH341A      (5E)  16pin socket
TVP2588U+   (40E) 32pin socket
RT809F      (40E) 16pin socket
RT809H      (40E) 48pin socket
