Author Topic: Dual Rail Power Supply Design Center Tap Connection  (Read 5509 times)
Offline D3KTopic starter
« on: August 26, 2012, 02:23:33 pm »
Hi All,
I am attempting to design my first linear dual rail power supply, and I came up with the following problem:
I have seen a lot of circuits on the internet and most of them connect the center tap connection of the transformer to the ground connection between the two filter capacitors at the input of the power supply ( figure attached). My question is that if the other two terminals (NOT centre tap) are being fed to the full bridge rectifier, what is the purpose of this connection?
The typical capacitances used as filters are very large, I have found one circuit with 10,000 uF capacitaces. Are these capacitances not large enough to guarantee a stable virtual ground for the power supply?
Thank you.
« Last Edit: August 26, 2012, 07:56:54 pm by D3K »
Offline PA0PBZ
Re: Dual Rail Power Supply Design Center Tap Connection
« Reply #1 on: August 26, 2012, 02:35:24 pm »
And how is the charge of the capacitors going to be divided between the 2 if your positive and negative load isn't exactly the same?
Or, why would you want a virtual earth if you can have a real one?
Offline madires
  • A qualified hobbyist ;)
« Reply #2 on: August 26, 2012, 03:11:05 pm »
The center tab is your ground connection. Imagine V1 and V3 are alternating around V2.
The capacitance is based on the current the prower supply has to provide and the ripple which would be acceptable for your application. Higher current and lower ripple equals to larger caps. Rule of thumb: about 2200 µF for 1 Ampere.
« Last Edit: August 26, 2012, 03:13:26 pm by madires »
Offline T4P
  • Country: sg
    • T4P
« Reply #3 on: August 26, 2012, 03:12:20 pm »
Center tap-grounding is a method used in full wave bridge rectifiers to attain positive and negative voltages
« Reply #4 on: August 26, 2012, 03:24:40 pm »
Thank you for your replies.
As regards to:
My initial query was that if V1 and V3 are fed to the full bridge rectifier, what is the purpose of having the power supply ground to the common connection?
Offline madires
« Reply #5 on: August 26, 2012, 04:19:48 pm »
I thought I answered that question :-) Ok , let's try another way. Since you want to have a dual rail power supply you need at least 3 terminals, one for +V, one for -V and a common ground which is related to +V and -V. The filtering caps are put between +/-V and the common ground. Actually that third terminal is missing at the right side in your picture. If you leave the common ground (V2) away you got a single rail power supply. But then you would only use a single filter cap or put both caps in parallel.
« Last Edit: August 26, 2012, 04:22:24 pm by madires »
Offline shebu18
« Reply #6 on: August 26, 2012, 05:17:56 pm »
I may be rude but if you don't know why they do that with the transformer than it would be better to read theory before starting to design. Gather more knowledge.
Sent from my GT-I5800 using Tapatalk
