Author Topic: floating outputs on psu  (Read 1996 times)
Offline amateur_25Topic starter
« on: August 26, 2012, 08:45:12 pm »
Hi
Am I correct in saying floating outputs on psu means you can swap the +ve and -ne to get a negative voltage?
If so does it matter if the pre regulator that feed the output regulator has a gnd pin?
Here's a block diagram
200va transformer ->rectifier -> l200c (has gnd pin) -> lt3080 (floating output)
Offline gxti
Re: floating outputs on psu
« Reply #1 on: August 26, 2012, 09:43:14 pm »
Negative voltage is simply a matter of choosing a reference. Even if the power supply's "ground" is the negative terminal, as long as it floats you can simply designate the positive terminal as ground and use it as a negative voltage supply.
