So, a driven shield, guard trace or bootstrap?
It's actually more of a positive feedback, but with limited gain (ideally exactly 1, from a voltage follower), so it doesn't (usually) cause instability*. There are a few other connections like that, where the output feeds back to the positive input in part, but it doesn't cause instability: Howland current pump, some active filters (the feedback effects peaking or ringing for a sharp response), etc.
*But that does suggest when it can go bad: when extra phase shift and gain shows up from an external network e.g. input filters, wiring L/C, unterminated cables, etc.
In the case of driven shields, you'll likely use it very little. I haven't had need of it myself, and I've been doing this for a long time. It's the kind of thing that, when you need it, you need it, and it might simply not be obvious if you haven't seen it before -- so it pays to have articles out there discussing it. But keep in mind, the amount it's discussed, is far out of proportion with how often it's actually needed!
The same goes for slotted ground planes, you need it very rarely if ever; and when you do, it's great. The insidious part is, it's very easy to misapply, and not even be aware of your misdeed. It's a lot harder to test things when you're rev-ing a dozen things at once on a PCB, and you don't know the results until the next prototypes arrive. EMC is a notoriously difficult subject.
So, for that part: solid ground planes are a surprisingly effective and practical "default" case. They can still be misapplied, but it's much harder to do, and doesn't go as badly when it does. And there are far fewer cases where you don't want ground plane (whether as slotted planes, or completely absent).
