Hello everyone
First of all i need to say: sorry for my bad English.
My circuit is based on this
http://www.radio-electronics.com/info/circuits/opamp_notch_filter_2/opamp_twin_t_varq.gifI used the active twin t notch filter with some modifications and got great results,
BUT sometimes the entire circuit becomes an oscillator.
The input recived the signal from a pasive instrument like a bass, guitar, even a dinamic microphone or
an active like keyboard, goes to a preamp and then to the notch.
Sometimes the oscillation happens when the signal input is too big like a beat, and it stops if you repeat the beat.
Sometimes it starts when connecting the power supply (a 9v battery).
I need to avoid this.. "parasitic oscillation"? "oscillation problem"?
I leave you images so you can see how i made the entire circuit and my modifications.
Thank you all in advanced
