Wow, you've packed a lot of interesting stuff in there...
Yes, I can see the value of humming a tune, the end result of which would be processed on the computer followed by a 'printout' as well - very useful for composing.
Re the chords - in my case with a hardware system, it's relatively easy to generate both major or minor chords derived from the primary (root) note in the form of control signals which are passed onto the midi controller together with the primary note control signal itself. (Hence the intervals are purely an electronic function associated with the primary note that is being hummed at the time.) But only a maximum of up to 4 notes can be played simultaneously - the primary note, a major or minor third, the fifth, and octave. (See enclosed pic showing the note module 'interval enable' SSR and 2nd pic showing primary note and interval note leds.) A separate control panel called the 'interval select module' permits selection of either major or minor thirds, the fifth and the octave as required. These additional notes may be selected and played while the primary note is being hummed and may be disabled at any time by de-selecting them on the interval select module. I particularly love the idea of using this feature with the 'SWAM' violin VST software - double stopping on a violin can sound so melodic. Normally such software (particularly SWAM) does not permit string instruments to play in excess of 2 notes simultaneously when using a midi keyboard unless the notes are struck at exactly the same time. However with my system, I can 'cheat a little' because the control signals all arrive at the midi controller simultaneously and hence all notes will be played. (I have actually introduced a slight delay on the note module between the primary note and any selected intervals to ensure precise synchronization.)
Now coming back to 'Mr R5' - yes, I've observed R5's influence over the filter tuning - I hear what you're saying by including R5 in the equation - thanks for that. I'm pondering on that one - maybe I'm hoping not to disturb the high Q and hence retain the very sharp selectivity when it comes to preventing unwanted adjacent semitone breakthrough. I'm dealing with filters which have a cut-off point of only +/-3Hz either side of centre. It's not much to come and go on. Hence the clamping idea is still a favourite in my mind.
You also raise a very good point when it comes to the actual calculated values for C & 2C. I have also found in practice that the calculated values don't quite correspond to the actual measured centre frequency on the board when sweeping the input with an online signal generator. (I use this program with an accuracy of 0.001Hz
https://www.szynalski.com/tone-generator/)
I find the capacitance values need to be lowered by about 1.5Hz which involves rather miniscule changes to the capacitor banks - normally I end up adjusting them to within about +/-0.5nF (about the maximum accuracy my capacitance meter will allow.) I've enclosed another pic of the capacitor banks.
Sometimes I wonder if the filters will retain their accuracy with such very fine tolerances. But after switching the system on and off many times, and retesting the centre frequencies multiple times after the system has reached normal operating temperature, I find they still seem to be perfectly in spec. Quite amazing really...
DSP versus analog? Well, for me, the answer to that one is fairly easy - I simply don't have the skills to work with DSP. I greatly admire people such as yourself, who have a very in-depth knowledge of electronic componentry. But for me, I just kinda stumble along with my rather limited design knowledge. There is another thing - I have already spent nearly 8 years designing and building this system up until now. I just dont think I have the heart to start pretty much all over again. It would also mean redesigning the PCBs which I have made in China.
I was very interested to hear that you also have a very large card cage like my one, and that you also made some PCBs for it. Were you also starting to build some form of voice to midi system? Or something else? I actually made this card cage myself and even that took me nearly 18 months to build. When it's back on its feet, I'll send you some more pictures of it. The whole affair looks a bit 'prototype-ish' but I guess I'm only trying to prove a point really.
Like the idea of you doing a Fourier analysis on your PC sound card. Hehe, good plan...
You asked if I found some software - were you meaning VST instrument software? This is the one I want to use:
https://www.google.com/search?q=swam+violin+demo&oq=swam+violin+demo&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTINCAEQABiGAxiABBiKBdIBCDQ4MzhqMGo3qAIAsAIA&sourceid=chrome&ie=UTF-8#fpstate=ive&vld=cid:af71f394,vid:H8Wu0Jr75VI,st:0Finally, if it's ok with you, I need to share with you why I feel 'so driven' to complete this project and how I see myself using it. Going back to 2015, I became seriously ill with abdominal cancer and needed major surgery. I became like a skeleton (the walking dead as it were) and very nearly died about 3 times. I couldn't help but feel (sorry, I'm not preaching here) that is was God himself who brought me through the cancer and 'Humming Burd' as I now call it, (or 'The Burd' for short) was a bit like a gift for God after bringing me through the cancer. Ever so slowly I began to recover, and with the recovery I found my mind was suddenly filled with all sorts of new innovations and ideas that I'd never really thought of before. And so really out of the cancer, 'Humming Burd' was born. I think when it is finished, my dream has always been to perhaps have a youtube channel with gentle worship music and love songs where people could come and relax. Humming Burd would be the centre-piece with the camera panning from my neck transducer to the PCB tower with its white PCBs & flashing leds, to the led-illuminated midi-controller and finally resting on the Swam violin graphics on the PC screen. What I'm really saying is, I'm hoping the burd itself would act as a draw-card to my channel because of its uniqueness and people would be able to rest because of the gentle music. I can't help but feel the burd would lose its uniqueness if I were to put it in the public domain. I spose also after coming so close to death, money doesn't have much of a hold over me. I think I just want to try and use the machine to encourage others. It's because of what I've come through. Gotta dream big dreams...
Well on that 'note' so to speak I'd better leave off here,
Thanks again for all your help,
I really appreciate,
Chat again when the burd is on its feet again.
