Author Topic: AD9851 with Hantek 4202C  (Read 610 times)
Offline DeboscopeTopic starter
  • Country: ae
  • Given enough time, tasks manage themselves
« on: November 17, 2019, 10:01:16 am »
Hi, I have ordered a AD9851 chip, what would be some interesting measurements to perform using this chip?
Excuse my newbiness.. :-DD
Offline German_EE
Re: AD9851 with Hantek 4202C
« Reply #1 on: November 17, 2019, 10:44:58 am »
The AD9851 is a DDS chip that accepts a clock of up to 180 MHz and generates a sine wave output anywhere between millihertz and half the clock frequency. Without some supporting circuitry around this chip including a CPU to drive it you will not be doing much.
Please read the data sheet for the AD9851 again
Once you have the control circuit built then you can generate a range of frequencies and perhaps see the response of RF filters using your oscilloscope.
Warren Buffett
