I'm trying to work out the INL error percentage from a ADC data sheet as a percentage.
If the datasheet says
Vdd_ref =- 3v0 (FSL full scale reference)
ADC INL is -+2LSB
Assume zero offset error
number bit is either 8
What is the percentage error acceptable at V_adc = 1V
Here is my calculations
for 8 bit ~ 256 levels
ADC LSB is = Vdd_ref/256 = 0.012V = 12mV
For the 1v ADC reading it can be:
Reading low 1v-2LSB = 1v -2x12mV = 0.976 IE -2.4%
Reading high 1v-2LSB = 1v _ 2x12mW = 1.024 IE +2.4%
IE the Error can be _+2.4%
