Hi-
I am working on a project, where I wish to sample the supply voltage to a subcircuit.
The voltage range is 14-16V. I want to scale and offset this to be sampled by a 0-5V ADC input (I may end up using a 4.096V external reference for the ADC, but the ask is the same regardless). The bandwidth can be extremely low, as I am only interested in slow changes to the supply voltage.
I have come up with the following two circuits:
1) Scale/offset with non-inverting op amp:
2) Use TL431 as regulated offset voltage (could also scale to full range with another op amp):
The tempco of the TL431 is pretty terrible, but the gain required by the first circuit makes me uneasy from an accuracy/noise perspective.
Which of these is better? Is there a better way of doing this?
Thanks
