Hi
For one of my projects, I am going to use ML8540. The problem I am having is in the selection of ADC to convert analog output from ML8540. I know it gives 6fps. So, below is my calculation for the minimum ADC sample rate from ADC to be selected,
1 fps = 48 x 47 pixels = 2256 pixels
6 fps = 6 x 2256 pixels = 13,536 pixels
the above means that I should select an ADC which supports minimum 13.536K samples. Am I right? ...The second concern is ADC resolution...The spec says the measurement range is -30 to +300C and 0.5C resolution, here, what is the voltage step per 0.5 degree change ?
please suggest...
Edited: Attached the spec of ML8540
Thanks,
Sangar
