Author Topic: ADCMT 6241 LabVIEW Example - Error When Running VI  (Read 193 times)
Offline Evan11223344Topic starter
  • Country: tw
« on: February 12, 2025, 04:21:55 am »
Hello everyone,
I am trying to control an ADCMT 6241 precision source meter using LabVIEW, and I encountered an issue when running the example VI provided by ADCMT.
System Setup:
ADCMT 6241 connected via USB
LabVIEW (2017 32-bit)
ADCMT 6241 official LabVIEW driver and example VI
Problem:
When I run the example VI, I receive the following error:
(Poly VI 'Read.vi':SubVI is missing)
Has anyone encountered a similar issue with ADCMT 6241 and LabVIEW?
Any suggestions on debugging or modifying the VI to fix this error would be greatly appreciated!
Thanks in advance! :) :) :)
