Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
“Adding” 4 audio signals?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: “Adding” 4 audio signals? (Read 1013 times)
240RS
Regular Contributor
Country:
on:
December 20, 2021, 11:00:55 am »
I have 4 microphones with 4 audio signals that I expect to sum op to zero. Ultimately I want to detect whether the sum of the signals is below a threshold.
I ran a test with two signals of which I inverted one. I fed those into an opamp and was very pleased to get the difference (which is the sum in reality). Believing I had found the way. But then got stuck extending that idea to 4 signals.
Which made me wonder: is there a standard way to add two and more signals? My signals are between -1 and 1V, 40 to around 1kHz.
Thanks!!
Logged
Berni
Super Contributor
Country:
Re: “Adding” 4 audio signals?
Reply #1 on:
December 20, 2021, 11:16:28 am »
https://www.google.com/search?q=op+amp+sum
Works for any number of inputs, just add resistors.
Logged
Jan Audio
Frequent Contributor
Country:
Reply #2 on:
December 20, 2021, 03:42:14 pm »
You wanto hear the audio ?,
then you need to use half the volume when mixing more harmonics.
You only detect the volume ?, then distortion dont matters, go to the limits.
Logged
Terry Bites
Super Contributor
Country:
Recovering Electrical Engineer
Reply #3 on:
December 20, 2021, 04:46:41 pm »
https://www.electronics-tutorials.ws/opamp/opamp_4.html
For least phase error use DC coupling where possible. The majority of modern opamps won't work as comparators. A TL07x?
Between the summer and the comparator you are going to need to turn the signal to DC. The Simplified Peak Reading Detector is the thing
https://sound-au.com/appnotes/an012.htm
Logged
240RS
Regular Contributor
Country:
Reply #4 on:
December 20, 2021, 07:09:36 pm »
Wow! Why had I missed that basic circuit. Thanks! And issue more than solved. No more inverting.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
